best plase to order a water pump for a 1993 225 evinrude?
bcraigan
I'm getting ready to tackle the beast and see if I can get this shaft loose and change a water pump. Any suggestions on where to order it from? Thanks. Craigan.
There is only 2 different water pumps for the V-4 and V-6 JOHNNY-RUDE carbed engines. One is for the early models and the other is for late model(roughly 92 was the change-over). I normally use the late model water pump kits in all of them that I do as they tend to have higher water pressure. They're $70.29 + tax straight from EVINRUDE for the complete kit part #0435929.
cheapest will be www.boatfix.com and go with Sierra Brand pump 18-3315-2 as they offer lifetime warranty if their product fails and causes motor damage they will replace the motor, and buy a complete kit as it includes the housing too.
Price @ boatfix $51.26
WATER PUMP KIT JE$69.99$51.26
Save $18.73SIERRA, INC.18-3315-2 / SIE1833152pg. 0[SIZE=+0][/SIZE]pg. 0[SIZE=+0][/SIZE]EA1Qty:
Search Mfg. Name, and/or part numbers:
Save $18.73SIERRA, INC.18-3315-2 / SIE1833152pg. 0pg. 0EA1Qty:
I had one of there impellers fail in my 98, and also had a sierra fail in a MERCRUISER outdrive. I now stick with all OEM for impellers.
agree with ferm on oem water pumps. might just be my imagination, but the merc pumps longer & stronger that the "look-a-likes" so in my 150. i also change impellor & housing at same time.
