Anyone recommend a good oil for the teak on my V20?
I need to treat the teak on my V20. Any suggestions on what to use?
I got some teak cleaner, the 2 step process and used the darker color teak oil, and it sure does make it look good. After a while however, every time your teak gets wet the oil separates from the wood and make a mess in the cuddy and in the floor. I sealed it after fighting it for a while with some teak sealer..a golden brown color and man I'm happy with it!
I would get the 2 step teak cleaner, and if you want to fight the oil for a while go for it . I found the sealer more user friendly:beer:
The 2 step teak cleaner is the way to go, and it helps to use a pressure washer. You need to be very careful, however, with the pressure washer so as to not damage the wood. I like to use a product called Sikkens Cetol marine finish. It is pretty expensive, about $35 a quart, but a quart goes a long way. It takes 3 coats initially, but the Cetol will last MUCH longer than teak oil or varnish. I have had it last several years without needing anything, and then just needing a light sanding and another coat. Cetol comes in several formulas. I have always used the original formula (just because that is what I started with), but they have a natural teak formula now that looks really good. The original formula has a slightly orange cast to it.
Thanks for the tips. I have never done it before and want to do it right the first time. Should I sand it down first or just pressure wash it?
