Just wanted to add some specs and a pic;
# Features: Digital Display
# 4,000 count, 20,000 count in high resolution mode
# Large, high contrast, easy-to-read digital display with an analog pointer
# 32 Seg Pointer
# Backlit display with on/off controls for easy viewing in all lighting conditions
# True-rms at readings to deliver the correct measurement, even when harmonics are present
# Automatic Touch Hold automatically triggers the meter to capture stable non-zero readings, freeing you to focus on the test probes
# Fused Current Inputs
# Continuity
# MIN/MAX Mode captures fast transients
# Peak MIN/MAX - 250 µSec (87 III and 87/E only)
# Relative Mode
# Diode Test
# Sleep Mode - 30 minutes
# IEC 61010 Rating - CATIII-1000V
# Battery access door that enables changing batteries without breaking the calibration seal
* Digital Display
* 4,000 count, 20,000 count in high resolution mode
* Large, high contrast, easy-to-read digital display with an analog pointer
* 32 Seg Pointer
* Backlit display with on/off controls for easy viewing in all lighting conditions
* True-rms at readings to deliver the correct measurement, even when harmonics are present
* Automatic Touch Hold automatically triggers the meter to capture stable non-zero readings, freeing you to focus on the test probes
* Fused Current Inputs
* Continuity
* MIN/MAX Mode captures fast transients
* Peak MIN/MAX - 250 µSec (87 III and 87/E only)
* Relative Mode
* Diode Test
* Sleep Mode - 30 minutes
* IEC 61010 Rating - CATIII-1000V
* Battery access door that enables changing batteries without breaking the calibration seal
