!986 V20 Factory Windshield Mounting
franko
Requested windshield mounting
Mounting consist of rubber grommet thru windshield (not shown)
Nylon spacer 1/2'
Finishing Washer SS
# 8 Screw 1 1/2"
Finishing Washer / # 8 Screw 1 1/2" ^
1/2 nylon spacer….Note:Grommet not shown thru windshield ^
HA! Nylon spacer!..... makes sense.... couldn't for the life of me figure out how to do all rubber without getting floppy...... (no wise cracks you Boston people... You know who you are LOL)
THANX
Smoke, on my Mitchell, I used short cut sections of a1 type fuel line, I just cut it about 1/4 inch long, the a1 one fuel line is thicker than normal fuel line, so it does a better job as a spacer.
i've used plastic retention collars from toro hydraulic irrigation valves,
much easier to get fuel line, great idea spare
good stuff guys... I'm gonna use a hole saw to cut spacers from a cutting board and then sand em nice n smooth by spinning with the drill
Just did the same type fix on my buddys kencraft "challenger" we used the small black washers from home depot in the plumbing section. They don't feel Luke the quite a rubber material there stiffer. They worked perfect. Just an idea.
tried em... need something much thicker and bigger around.... just didn't think of hard plastic before
Just be careful when mounting your windshield. Too much torque and you'll crack the Plexiglas around the mounting hole like we see in the first picture. Whenever I've had to mount plexi to anything I prefer a softer material (like hard rubber) that has a certain amount of "give" for just that reason. :head:
