3.7 harmonic balancer
aussie
Hi guys someone asked me about what balancer i was going to use on my 3.7 i did a bit of research apparently you can use any ford v8 one that donent have a counter weight in it or you can buy a aftermarket one that gives you the choice to have the weight on or not as its bolted on just remember you may have to find a pulley for the belts to line up its not a bolt on fit whenim up to the stage ill tell you whyat pulley i used and what car it was off cheers
what happened to the original one? If we had one that the magnets were broken, we'd knock the rest of the magnets out and reuse it if we were installing an external altenator..
BTW, I have a brand new in the box factory Mercruiser balancer for a 3.7 that I'll make some one a deal on
