1996 Johnson 150
F.R.E.D.
Been attempting to locate an engine harness for model# J150EXED. Any leads? It appears part is discontinued but there must be aftermarket solution.
I would also like to replace boat harness. To the best of my knowledge gauges (no indicator tach), switches and breakers are original to boat. I have located part# 0176341 @ 20'. I have a 96 V-21 that should be more then enough length and correct part, right?
Scrounge the junkyards and used engines on craigslist as there is no aftermarket solution. Either find a used one, or fix yours. As to main harness's, they can be found on ebay and all over.
Well after a few hours of research I learned quite a bit. Despite being model year 96 my motor is actually a 95. So the service manual I have may be of limited use. I will get a 95 manual on the way. I was able to locate a new engine and boat harness . . . for others in the market they are out there but you got to do a lot of searching.
Does anyone have a 95 motor with safety check gauges? I think I will be upgrading to this set up since I have plans for all new switches, breakers, engine harness, boat harness, etc. Looks like all I will need is a tach and adapter plug. Anyone know the part# to install 96 system check on 95 harness?
Call Ed at J&B Boat - he'll tell you 856-456-0102
