18 CC with Bracket
regidog
Has anyone put a bracket on a 18 center console? I know I have seen pics and read several people say they were going to do this but has anyone on here done it and how do you think it would perform with a 90 to 115 hp outboard?
Reg, I don't think anybody has done it on this forum on an 18'. I think a number of people feel that the 18' may be too small for a bracket; some think it may cause the boat to be prone to porpoise.
I think your biggest problem would be the weight extending much further off the transom in a 18 footer, unless you used a small light weight engine and got a very light bracket you will be to low in the arse causing all kinds of problems
Ya thats kinda what I thought but some came with a seadrive so I figured I'd ask. What do you do with one of these factory seadrive hulls once the seadrive is shot?
If you didn't want to put a bracket on one, perhaps you could cut the transom just enough to allow for an outboard to be hung on it or just enough to allow a jackplate to be installed and allow room for the cowling to clear when tilted up...
Just a thought.
Yeah i WAS going to do it after seeing this one locally.
I had a bracket and everything, but after some research and deciding I would be fishing inshore/shallow water more than offshore so I thought better of it. Instead I went with a jack plate and that helped me gain a good bit of room in the rear so I'm happy. Unless you have a full transom 18 that had a sea drive I wouldn't do it. Even then if I did I would use the shortest, lightest bracket possible and no more than a V4. I plan on changing to V6 power (150 or 175) so a bracket is a no no for me. IMO the 18 is really a$$ heavy anyways. I have moved two of my three batteries to under the console to combat this and it has helped tremendously. The boat sits nice and level at rest now and planes out wonderfully. It also handles at speeds MUCH better as a result. I would also do this for sure on a bracketed 18.
I think its definitely possible if following these few parameters. if you do it keep us updated! id like to know how it goes!
