spareparts
God
I've officially put my 16 McKee up for sale. I've completely gone thru the boat in the past two years. Not much on the boat I haven't had my hands on. In the past two years:
New wheels/hubs/lights/bearings/springs/rear cross member/ bunks and brackets(new winch coming this week)
Boat has new steering(uflex no feed back), control cables, water pump, thermostats, fuel pump, power pack,gear lube, spark plugs, fuel line, fuel filter, battery cable. battery switch, battery. I went thru the carbs. Compression is all with in 5 lbs of each other. Just did a decarb on it. All new wiring expect for the engine harness.new guages, new key switch, new switch panel, new fuse block. New fuel tank, primer bulb, fuel line. New center console. Leaning post is used but has a new cushion on it. leaning post is wired for 12V. I filled in the forward area between the side storage compartments with epe' decking to make a casting platform(looks pretty good). I put a Lowrance x4 depthfinder/gps on it. I took it out last week and it ran 42 mph wide open with me in it. The boat is not the prettiest thing, but its solid. It was originally a duel console that the person before me converted into a center. The inside could use a paint job, the outside is better and just need washing. The engine runs like a sewing machine. Transom and floor are solid.
$3500 as is. I plan to install a new bow light and replace the winch as soon as I have time. Boat is located in Goose Creek, SC(near Charleston). Taxes are paid up and registration is current. I'll add pictures after I give it a bath. IF anyone is interested, pm, email or call. qualitymarineservice@yahoo.com (843) 532-9148
